Check Ball In Fuel Pump
Old Aug 19, 2002 | 01:59 PM
fastvetteTPI84's Avatar
Does anyone know where the check ball in the fuel pump is located and if it is serviceable .....i have started to notice after leting the vett sit over night it takes longer to start i checked the fuel pressure after shuting it off and it quickly goes to 0psi in less then a min ...now i would asume that the check ball is stuck ,can i fix it or is it time for a new one .
thanks
Old Aug 19, 2002 | 04:48 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I'm not sure that's your problem. I'm on my 2nd fuel pump in the IROC that's done that. My pressure bleeds instantly, but the car still fires quickly.
I've also verifed that it's the pump that's not allowing the pressure to hold, and not an injector or the FPR.
Old Aug 20, 2002 | 10:51 AM
tpi_roc's Avatar
Jims got it
Bleed off would either be a torn or miss seated diaphram in your FPR or a leaky injector
Old Aug 20, 2002 | 11:12 AM
Morley's Avatar
There isn't a "check ball" in the fuel pump. It is a diaphram type checkvalve and is inside the pump which is a crimp sealed unit, no service possible. If everything points to the fuel pump and you are set on changing it, check it when you get it removed by blowing in the upper end and see if air comes out the bottom. If no air comes out then the pulsator could be bad.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Newguy91rs
Aug 7, 2015 09:51 PM
