fuel problem
Old Aug 20, 2002 | 08:45 PM
demon138's Avatar
Car: 89 Pontiac GTA Trans Am
Engine: T.P.I. 383 Stroker
Transmission: Monster 700R4
fuel problem
my car wont start.i thought i had a bad filter so i changed it. when i turn the key forward the pump pressurizes but when i check for pressure by pushing down the little valve on the fuel rail it squirts and stops nothing comes out afterwards. i turn the key back then forward again and the same thing. what does that mean?it shooting trouble codes 33 34 ? but i just bought a new maf sensor what is the deal??????????
Old Aug 21, 2002 | 05:38 PM
chriscamaro87's Avatar
same thing
I have the same thing wrong. I hooked up a pressure guage and read around 40 psi. Could you have good fuel pressure and still have a bad pump, or filter?????
Old Aug 21, 2002 | 08:15 PM
Astro's Avatar
Take a fuel pressure gauge and check fuel pressure, if its really low then a new fuel pump is order. Im having to do that right now, my fuel pump will pressurize and bleed off quickly. Replacing it tomorrow, yippee.
Old Aug 21, 2002 | 09:20 PM
SHO350's Avatar
Car: 1991 Trans Am
Check and make sure the MAF sensor is getting the 12V it needs. The fuel pump relay could be faulty.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
