how do i check if injectors are good?
Old Aug 22, 2002 | 06:51 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
i bought an lt1 intake with 24# injectors, the whole intake including injectors have some oxidation on them. before i put them in, is there a way to test the injectors?
Old Aug 22, 2002 | 07:00 PM
AlexJH's Avatar
Engine: 5.7L V8
I'm not sure if LT1 injectors are the same, but usually you can check the resistance to see if they are ok.
Since they're off the car right now, why not send them to get cleaned and flow matched?
Old Aug 22, 2002 | 08:43 PM
Car: '87 Camaro LT
Engine: 355 L98
what's it cost to send them to get cleaned and flowmatched? do you know what the resistance is supposed be? thanks
Old Aug 25, 2002 | 09:24 AM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
On LT1 injectors you should see about 12.5 ohms or so.
Old Aug 25, 2002 | 12:39 PM
Jza's Avatar
Jza
about $10 each
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Brcharrelson
Aug 26, 2015 07:47 PM
twest2k2
Aug 24, 2015 11:26 AM
justin57
Aug 20, 2015 07:05 PM
