LT1 conversion questions
Old Aug 23, 2002 | 12:06 PM
Hodge's Avatar
Car: 1987 IROC-Z28
Engine: 383 Vortec - carb
Transmission: T56 - 6speed
Should be pretty simple questions for anyone who has done it.
1) Without the EGR how do you make the ECU not throw a code without a custom chip?
2) does the LT1 intake work with any style stock TPI heads. (i.e. center bolt or perimeter bolt )
3) Aside from the custom fuel lines and remote T-stat housing how much extra did you spend on other miscelaneous pieces to complete the install (i.e. hoses for the T-stat etc.)
Hodge
Old Aug 23, 2002 | 12:13 PM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
Only way I know of for the EGR is with a chip that has the EGR taken out of. But I have heard some people say that it doesnt throw a code if done rite. You'll want a chip anyway, the LT1 flows sooooo much better then the TPI and it wont take nearly full advantage of the power with a stock chip.
Yes it bolts rite up to the heads, the valve covers dont matter. You tell John what years your heads are from and he makes the intake the rite angle for it.
Some little stuff is 2 heater hoses ($30, they are long), a waterneck ($5), a TV Cable bracket ($7), you have to grind, or cut, away part of your alternator bracket ($Free). hmmmmmm depending on what style distributor you have you might need a new one. ( I got mine free from a friend) you need the small cap style with the remotely mounted coil.
Oh yeah, you need, its either 2 or 3 fittings ($2-$3)that screw into the remote mount housing that connect to the heater hoses.
I dont think Im forgetting anything.
Hope I helped
Brian
Old Aug 23, 2002 | 12:58 PM
Hodge's Avatar
Car: 1987 IROC-Z28
I plan on getting into chip burning. I was going to get into that first but I had to take my intake off for other reasons so I thought that now would be a good time to do the conversion then I'll get into chip burning next.
that's what I wanted to hear
Hope I helped
that helps a lot.
Brian
thanks
Hodge
Does anyone know the "trick" to not setting a code until I start burning PROMs??????
midge54
Dec 27, 2019 04:14 PM
87iroctheo
Dec 4, 2016 11:47 AM
midge54
Aug 29, 2015 09:51 PM
lt1z350
Aug 28, 2015 05:57 AM
redmaroz
Aug 16, 2015 11:40 PM
