Stealthram install complete
Old Aug 25, 2002 | 04:18 PM
88TransAMgta's Avatar
After only having to wait a whole 3 weeks to have my stealthram and fuel rails delivered a week later the install is complete. Results:
The car has losta ton of low end but for th3e gain up top id gladly say goodbye to it. The car pulls sttrong to 6500rpm with out a hitch.
Im running this thing with a stock chip (no prom tuning) and with the other mods listed in my sig.
Old Aug 25, 2002 | 04:22 PM
Oh yeah, and the Stealthram does clear the stock TA hood with some clearancing. I just cut out the cross brace that sits just over the intake
Old Aug 25, 2002 | 05:31 PM
u r sofa king we tah did's Avatar
how did you do your fuel lines.
Old Aug 25, 2002 | 06:57 PM
matlock's Avatar
Car: 89 GTA
I saw your car at mission on friday. Nice car man. You gonna work out your bugs and race on the 30th? Would be cool to see a sprayed run. I may show up, my buddy with his modified 89 5.0 wants to race me again so he can attempt to beat my stock gta . A stealth ram is definately in my future when I get some cash and time.
Old Aug 26, 2002 | 08:59 PM
For the fuel lines i ran custom lenth braided steel line with dash6 fittings on each end and i used Earls fittings to join the lines to the stock rubber lines. I cant remember the exact p/n right now but ill see if i can find them later.
Yeah that was me at mission it was a pretty sad day, for me anyways. I had bad luck all day, was in a huge rush to get the car running this week that i didnt have a time for tuning it and the time slips (which i wont post) deffinatly showed that. The stock chip isnt helping any either. Oh well ill just have to wait untill the dfi comes in then ill go tuning crazy.
Anyways if anyone has any other questions about the install just ask and ill see if i can get a hold of a dig. camera to take some pics for you.
Old Aug 26, 2002 | 11:58 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Would like more info on the fuel line thing. I have a stealth ram waighting to be installed also. I have to get the trans back in first though. Dammd 700 only lasted 3000 miles.
Old Aug 28, 2002 | 04:40 PM
FormulaGod's Avatar
I would love to get a step-by-step rundown of the fuel line install. I HATE fuel lines modifications so i know im gonna fumble it big time. I ordered the fuel rail fitting kit, (two fittings) so i have that. Pics would be good too!!!
thanks.....:hail:
Old Aug 28, 2002 | 04:51 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
I cut my stock fuel lines as they start to bend upwards right next to the trans on the inside of the frame rail. There I installed two compression fittings, and used 3 feet of steel braided line on both the return and supply lines. All of this cost me $103 in lines and fittings and the labor to fab the lines.
Old Aug 28, 2002 | 08:32 PM
bbunting's Avatar
Car: 1990 IROC Z
Engine: blown 390 CI
Transmission: TKO II
These are available as a kit
http://community.webshots.com/photo/...47047006IZCilC
Old Aug 28, 2002 | 09:14 PM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
why????
why not just use some rubber hose and clamps? it's cheaper!!!
i noticed that the return and the feed line is on the same side???
isn't that going to mess with your fuel pressure???
Old Aug 28, 2002 | 09:20 PM
bbunting's Avatar
Car: 1990 IROC Z
Badgta- if you are referring to my photo, the one line is for an external fuel pressure gauge, not the return line. The number one reason that you wouldn't use rubber hose with clamps is safety.
Old Aug 28, 2002 | 11:51 PM
JMatlock88's Avatar
Car: 1991 Formula
They make some hose clamps (on steriods) for use with fuel injection pressures, but IMHO they're still not sufficient. Neither are the aluminum earls fittings that tighten on each other to hold to the hose. Both of these will never hold up as well as machine-pressed fittings.
Old Sep 1, 2002 | 09:34 PM
Gta-Paladin's Avatar
88TransAM How much did everything come to in Canadian after the shipping and brokerage was all said and done?
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
toronto formula
Nov 10, 2015 06:17 AM
KO1
Aug 31, 2015 06:31 PM
