TPI HEADS ????? CAN USE ??? TPI INTAKE ANGLE same as older heads
Old Sep 2, 2002 | 07:26 AM
LARRY Hedge's Avatar
89 L98 TPI. want to upgrade heads . i have a set of big 76cc 202-160 heads from old 350 motor 75-78. other than center bolt issues am i looking at any problems?? P.S. mortec says my 89 heads suck. plan on a little cam upgrade.
Old Sep 2, 2002 | 07:45 AM
kevinc's Avatar
Car: 1982 Z28
With that huge chamber size these heads won't be an upgrade, you'll lose compression in a big way.
Check the accessory holes on the fronts/rears of the old heads to see if they're in the same location as your current heads. When I bought GMPP aluminum heads, I had to have the shop add a hole for the serpentine accessory brackets on each side.
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
86White_T/A305
Aug 17, 2015 12:16 AM
89mulletbird
Aug 12, 2015 07:08 PM
Sanjay
Aug 12, 2015 03:41 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
