Afpr
Old Sep 4, 2002 | 05:08 AM
DOOSKI's Avatar
Car: 1990 Trans Am GTA
Engine: 5.7 TPI 350 sd
Transmission: A4
Afpr
On what psi should i set the AFPR for most performance, the car is a almost stock 350 which will get headers and ported plenum
THANX
Old Sep 4, 2002 | 11:21 AM
tpi_roc's Avatar
The idea of having an adjustable fuel pressure regulator is so that you can tune YOUR car, any two thirdgens are almost garunteed to be off 1-3psi on fuel pressure even probably from the assembly line... Find the pressure that works best for your car by picking a starting point (42psi?) and run a quarter mile, then bump it up and try again, and up and try again, when you stop going faster, or start going slower, back up and stop there
Old Sep 5, 2002 | 03:51 PM
DOOSKI's Avatar
Transmission: A4
ok thanx!!! should i put headers in before i adjust the afpr!
Old Sep 5, 2002 | 04:20 PM
tpi_roc's Avatar
Shouldn't matter, a proper tune is important at any stage int he game so you can before/after...
I'd recommend before and after
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
alpine247
Sep 16, 2015 05:25 PM
355tpipickup
Sep 4, 2015 05:32 PM
