one quick stupid question
Old Sep 5, 2002 | 09:17 AM
TunedPortZ's Avatar
i have a quick question that may be stupid, but will not having a functional knock sensor make your car slower?
Old Sep 5, 2002 | 10:37 AM
Morley's Avatar
Yes. At times during driving the computer does a "self test" on the ESC system, if it fails, it reverts to a fail-safe timing scheme which basically removes the ********* from the car.
tpi_roc's Avatar
Depends on if you're knocking or not and how bad.
assuming you're not detonating and you're running a good timing curve no it shouldn't slow you down, its just a big engine damage risk.
Old Sep 5, 2002 | 06:35 PM
RBud350tpi's Avatar
The only time I have ever felt slowed down by it is when the car was hot, on a hot day and I hit the gas about half way off idle. One big spark knock and the car lost power so I crused on home and modified my fans.
Old Sep 5, 2002 | 06:39 PM
tpi_roc's Avatar
If you're knocking yea you'll lose power, and heat will deffinatly help knock out.
Its a cheap enough part to keep your engine running that I would never run a car withotu one
Old Sep 6, 2002 | 07:18 AM
TunedPortZ's Avatar
well i was going to replace it yesterday, i already have a new one, but isnt there a special way you have to put it in?
Old Sep 6, 2002 | 11:20 AM
Morley's Avatar
Just don't under or over torque it. And watch for the coolant.
Cleotiz
Jan 6, 2018 08:56 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
gta power
Aug 13, 2015 06:15 AM
