code 24/ vss
Old Sep 6, 2002 | 07:21 AM
Irockin's Avatar
code 24/ vss
My speedometer stopped and the check engine light came on. I did the diagnostic and code 24 comes up. I switched out the speedometer, as well as the Vss buffer behind the speedo, but still no change. The cable is plugged in and appears to be doing its job. Does anyone have an idea of what I should check next?
I have a 1989 convertible Iroc (305tpi w/5speed)
Old Sep 6, 2002 | 08:19 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
What do you mean by no change? You mean the speedometer still doesn't work?
And, what do you mean by the cable appears to do it's job. Try jacking the back of the car up and driving the wheels. Is the cable turning?
You could have a broken cable, or stripped speedo gears in the tranny, or 2 bum speedos. Pretty much has to be one of those...
Old Sep 6, 2002 | 08:23 AM
Irockin's Avatar
Ed, thanks for the reply. By "no change", I mean that the speedo still doesn't work. The service engine light comes on after driving the car about 2-3 minutes. I will do as you suggested and post the results.
Old Sep 10, 2002 | 06:24 AM
Irockin's Avatar
Upon further review, it turned out to be the speedo cable. I was broken at thr transmission gear. Thank you for your ideas Ed.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
