Can I use my 86 TPI setup on my 350 swap??
Old Sep 7, 2002 | 02:26 AM
Bimma86's Avatar
Car: 1986 IROC-Z
Engine: 355 TPI
Axle/Gears: 3.23 Posi
Well I am going to go with this engine for my swap I think. http://www.goautocenter.com/300hp_tpi_1987-89.htm So I need to know if my specific 86 TPI unit will fit up to a 87+intake that I will purchase for this engine? If not what would I have to change on it to make it work??? Thanks guys for the help!
Old Sep 7, 2002 | 11:45 AM
Morley's Avatar
You just want to know if your '86 plenum, runners, fuel rail and throttle body will work with an 87+ manifold? Yes. Except for the 89 manifold that had no provision for a cold start injector, you'd need a plug for the hole in your driver side runner and for the tap off on the back side of the fuel rail.
Old Sep 7, 2002 | 12:06 PM
Bimma86's Avatar
Car: 1986 IROC-Z
Engine: 355 TPI
Thanks man you helped me out cuz I was wondering about what I would have to do to the plenum and such.... Thanks!!!
bellez77
Sep 5, 2015 08:39 PM
Sanjay
Aug 12, 2015 03:41 PM
armybyrd
Aug 10, 2015 09:23 PM
squiggy2
Aug 9, 2015 09:30 PM
gwade12
Aug 8, 2015 08:17 AM
