Which Heads
Old Sep 7, 2002 | 07:03 PM
Trent257's Avatar
Which Heads
I want to take my l98 and bore it .030 over and put a 83 stroker, with a holly stealth ram intake, and a cam and heads, which cam and heads should i look at, i was thinking afr heads.
Old Sep 7, 2002 | 08:13 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
I'd go AFR 190's. As for cam, I haven't seen much on good cams to use with the HSR, but I would guess something a little bigger than the HOT cam would be good.
Old Sep 7, 2002 | 09:25 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Heads have always been the key to power with a SBC.
If you got the cash, AFRs if you want to remain "Standard 23* Chevy", like aluminum and use EFI. For "iron" I like Pro-Action Lightning. I believe they now have smaller intakes that will work well with the EFI setup. But Pro-Action is more of a "race head" for big cc intake manifolds. If you want to go EFI and a "big cc head", then you will be stuck with the Miniram. Unknown to most people, but TPIS does make a "big port" Miniram. The regular Miniram does have limits on how big of an intake port you can match it too. I believe 210s is either at or just over the limit with the "regular" Miniram.
Old Sep 7, 2002 | 09:45 PM
BuckeyeROC's Avatar
Great info Glenn, I did not know that about a big port MR. You know how much more it flows over regular? I may have to remember this for my dream 427 Motown buildup.
Old Sep 8, 2002 | 10:31 AM
Car: Death Mobile
Engine: 666 c.i.
No. In fact, I don't know what the regular Miniram flows - TPIS doesn't publish those figures.
I found out about the "big port" Miniram from another moderator. He was running the "regular" Miniram and wanted to upgrade to AFR 210s for a turbo SBC project. He had been running AFR 190s with his Miniram and found out the regular Miniram ports were too small and didn't have much metal left if you port matched it.
That is how I got my Miniram
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
