LG4 to TPI
Old Sep 8, 2002 | 08:28 PM
pauldaniel26's Avatar
Car: 1986 IROC-Z28
Engine: 355 in the works...
LG4 to TPI
Has anyone ever swapped TPI onto an LG4? What were the results? Is it worth it? I'm really sick of having a carb!
Old Sep 8, 2002 | 11:52 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
TPI's I know, engines? What exactly is an "LG4"?
Old Sep 9, 2002 | 10:31 AM
Car: 1986 IROC-Z28
The LG4 was the base carb'd motor put into Camaro's/Firebirds. Currently my motor has NO sensors on it at all because the computer was taken out.
Old Sep 9, 2002 | 10:55 AM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
Well its swapable, you would of course need all the sensors components, and harness. You would also have to swap on a set oc centrbolt heads, which the TPI is designed to mount to.
You better change that cam in there though, otherwise your still gonna have that 165 hp peanut cam!
Old Sep 9, 2002 | 01:51 PM
Car: 1986 IROC-Z28
So the TPI won't bolt up to my heads?
Old Sep 9, 2002 | 02:39 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
It will bolt up. You may have to elongate the center holes in the manifold, though.
Old Sep 9, 2002 | 04:23 PM
fb305svs's Avatar
Yes, you coudl do that, but the centerbolt heads have larger valves and slightly better flow numbers!
I guess its a money issue, but if your gonna yank that intake, i would recommend going the extra step and getting that anemic cam the hell outta there!
RazorN8
Jan 7, 2022 11:44 AM
podiatra
Aug 31, 2015 09:53 AM
ambainb
Aug 29, 2015 12:43 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
