New Engine Runability Problems - Help!!
Old Sep 11, 2002 | 01:22 AM
TPICherokee's Avatar
I just put a new engine in and it seems to run like total garbage. Here is what I started with:
86 Camaro 305 TPI
Stock
Here is what I ended up with:
88 Camaro Engine (Roller)
86 Camaro TPI
Vortec Heads
Scoggin Dickey Intake
19lb Ford Motorsport Injectors
9.5:1 Compression Ratio
Roller Rockers
All New Sensors
Distributor and Coil out of an 88 (small cap)
Roller Rockers
Comp Cams 08-501-8 Cam Specs on cam:
Intake Exhaust
Gross Valve Lift 0.488 0.495
Duration At 0.006 Tappet Lift 264 269
When I first had it started it ran great!!! Then I checked to make sure that the timing was right and it was about 18 degrees advanced. The manual said that these are supposed to be set at 6 degrees so I changed it and it doesn't run well at all. Could this be because the distributor change. As I recall the HEI that came out of this still had some mechanical advance built into it. This new distributor doesn't.
Yes I know that part of my problem is that I am still running a stock 305 computer but I just wanted to make sure that I didn't shoot myself in the foot with any of my mods. Please help!!
Old Sep 11, 2002 | 03:15 PM
tpi_roc's Avatar
Does your timing advance like its supposed to when you raise rpms? (check with light)
also did youput in a 350 knock sensor or a 305 knock sensor.
Whats the cam duration @ .050 and the LSA
Old Sep 12, 2002 | 01:32 AM
I used a knock sensor out of an '88 350 (I remember reading that on this board awhile back!)
The duration is given at .060 and here it is:
Intake 264
Exhaust 269
Not to sound like an idiot but it's late and I can't think of what LSA stands for????
No, I didn't check to see if it advances with the light... I will check that tomorrow. Thanks!
Old Sep 12, 2002 | 07:31 AM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
Did you remember to unhook the EST wire on the firewall before setting your base timing to 6*?
Old Sep 12, 2002 | 10:35 AM
Morley's Avatar
LSA= Lobe seperation angle
Old Sep 13, 2002 | 10:55 AM
AHA! Got it. Yes I did disconnect that wire before I set the timing.
The LSA is 112.
Thanks again.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
