Smog Pump
Old Sep 11, 2002 | 10:48 PM
Vicious 88 GTA's Avatar
Smog Pump
If I was to remove the smog pump, the A.I.R. or whatever it is called and put on a set of Hooker Shorty Headers on my L98, would this make a noticeable diffrence or not really???? Thanks.....AARON
Old Sep 12, 2002 | 12:21 AM
iroc22's Avatar
The Smog pump is really only stealing 2hp from you at most from the belt. It weighs about 10lbs though and removing it will make your nose lighter, making a better front/rear balance.
The headers should give you lots of horsepower over manifolds.
Old Sep 12, 2002 | 12:26 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
The thing you will notice most is the space....
Old Sep 12, 2002 | 03:33 AM
914Mula's Avatar
Car: 91' Formula
Engine: 383CID
Transmission: t-56
Axle/Gears: 4.10
Removing my A.I.R. system was one of the first thing i did along with installing headers. I definitely recomend both mods if emissions allow.
Old Sep 12, 2002 | 10:56 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Don't forget headers weigh a lot less than manifolds as well.
Old Sep 12, 2002 | 11:45 AM
Hodge's Avatar
Car: 1987 IROC-Z28
Engine: 383 Vortec - carb
Transmission: T56 - 6speed
headers are by far on of the best mods to make on a TPI engine.
In my opinion
italiano67
Dec 11, 2016 09:21 AM
J.C. Denton
Aug 31, 2015 03:11 AM
Victor6
Aug 30, 2015 02:09 AM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
mustangman65_79
Aug 7, 2015 09:55 PM
