12's or low 13's on this setup?
Old Sep 12, 2002 | 12:32 PM
86IROC-SS's Avatar
1986 IROC-Z (for weight purposes)
91 corvette L98
Polished Ported Heads by FLP
Superram Full Intake Manifold
<Insert cam> looking for a streetable cam that will give moderate gains
Edelbrock TES headers
FLP HiFloCat
Flowmaster catback <Ravin Muffler>
58mm LPE Throttle Body
K&N, cold air
FLP level III trans
2800 stall
3.73 rear end, TA girdle (thats 10hp)
Hypertech Custom Chip (no time to get into PROM burning)
Thats it, the street tires are 275 width,
Guesses with and without drag radials...?
Thanks alot,
Matt
Old Sep 12, 2002 | 12:56 PM
brian89transam's Avatar
Are these mods that you've done, or mods that you're planning on doing? As far as I know, hypertech doesn't make custom chips... And If you really don't wanna get into PROM burning, you'd be better off to tune w/ timting advance and an adjustable fuel pressure regulator. Anybody that knows anything about PROMs on these boards will tell ya that hypertech, jet, ads, etc. (all off-the-shelf chips) really suck and are worthless for most people.
I don't know why this setup wouldn't see 12s with good traction (and a good cam). Just make sure it's runnning good and tuned properly.
Old Sep 12, 2002 | 04:09 PM
86IROC-SS's Avatar
thanks for the reply, thats the setup after. Right now its everything but the heads, cam, intake. (Which pretty much is the most important stuff). But the drivetrain seems to be ready for it.
Matt
Old Sep 12, 2002 | 04:16 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Instead of buying a hyperjunk chip, buy PROM burning equipment. Even if you burn one chip with it you will outdo the hyperjunk.
Old Sep 12, 2002 | 04:38 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Yeah, I see 12s easily with a little traction and tuning. I'd say low 12's setup correctly. As for a PROM, hypertechs and the like are JUNK! After just putting in this motor (mods in sig) I was running the hypertech chip I had. It ran ok, but rich. Now me and a friend are doing a chip for it. Very cheap and easy to play with. I was once like you, but will definately stick with custom proms by me or a friend from now on! Good luck with the car. It should do great with traction/tuning
Old Sep 12, 2002 | 05:33 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
I'd say low 12's too (with Drag Radials, which are also my street tires), check my sig below. How well those heads flow will be the key to your combo. Heads are critical for making power.
As for cam, I DEFINITELY recommend the LPE 219/219. IMHO, there is no better cam for a 355 or 383 with a SuperRam on it.
I would also recommend SLP headers or Hooker Super Comp's instead of Edelbrocks.
db057
Apr 28, 2019 07:45 AM
TheExaminer
Sep 6, 2015 11:40 PM
SG91camaro
Sep 5, 2015 10:27 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Formula_88AE
Sep 3, 2015 01:47 PM
