Where can i find TPI fuel rail part numbers?
Old Sep 16, 2002 | 05:58 PM
PerfectionGoku's Avatar
Car: 98 Camaro Z28
i am trying to find a site that has part numbers for my 87 gta to see what type of fuel rail i have plenum part numbers intake etc... i need to find out if its a 350 fuel rail or a 305.
Attached Thumbnails Where can i find TPI fuel rail part numbers?-my-gta-doing-burnout.jpg
Old Sep 16, 2002 | 07:30 PM
rezinn's Avatar
To my best knowledge 305 and 350 cars use the exact same fuel rails. The only difference is the fuel injectors, which you can ID pretty easily if you read the numbers off of them.
Old Sep 16, 2002 | 11:03 PM
Guest
Guest
Posts: n/a
Yea, he is right. 350 and 305 fuel rails are identical. The only difference in any TPI fuel rails are cold start or no cold start, and Corvette or F-body.
Old Sep 16, 2002 | 11:27 PM
Car: 98 Camaro Z28
how can i tell if i have 350 injectors, i am putting a new 88 camaro 350 L98 in it and i am not sure if that engine is a 350. the vin says it is but i took the car to the dragstrip the best it ran was a 15.9 at 86mph with 3.45 gears.
Old Sep 17, 2002 | 08:33 AM
S10Wildside's Avatar
Your last post was a bit confusing. You are putting in a 1988 L98. The L98 is a 350, never a 305. Look on the rear of the block, on the driver side. If it's a 350, you'll see "5.7" back there.
Old Sep 20, 2002 | 12:08 AM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
Confusion? Where? Go here and find all your part numbers and applications. http://iroc.fbody.com/
1992 Trans Am
May 10, 2023 07:19 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
armybyrd
Aug 10, 2015 09:23 PM
1nastygta
Aug 8, 2015 07:38 PM
92projectcamaro
Aug 6, 2015 01:20 PM
