what compression ratio will i have
Old Sep 29, 2002 | 08:52 PM
87 B4Z's Avatar
Assuming I have the thinnest head gasket available, what compression ratio will I have with aluminum L98 heads on a 305 with stock pistons?
Old Sep 29, 2002 | 09:26 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Rough guess is between 9 to 1 and 9.3 to 1. Thats with 58 CC heads, .015 FelPro 1094 head gasket and around 13 CC in block and pistons.
Old Oct 1, 2002 | 09:47 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I thought that you couldn't use 350 heads on a 305 block. I remember reading that you have to clearance the piston bore because the valves hit the edge.
Old Oct 1, 2002 | 10:35 AM
Vader's Avatar
87 B4c,
Figure it out for yourself. Load and open this calculator:
Engine Calculations.xls
It works with MS Excel and QuattroPro.
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
