Benifits of porting LT1 intake?
Old Sep 30, 2002 | 11:37 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Is it worth the time to polish the runners on the inside? I'm not lookin to pull the heads and port match them, just clean up the intake a little. Anyone done this or have pics of someone who did? Thanks in advance. :hail:
Old Oct 1, 2002 | 09:54 AM
Vader's Avatar
FB,
Porting is fine, but don't ever waste your time polishing the intake runners. There is no practical benefit from this, and it may be dedtrimental.
I had to port my LT1 intake to match the head ports/flow:
Old Oct 1, 2002 | 10:15 AM
S10Wildside's Avatar
Vader,
How'd you match the intake to the heads? Did you use a gasket as a template?
Old Oct 1, 2002 | 10:40 AM
Vader's Avatar
S10,
When porting time rolls around, I tend to use up lots of old playing cards and Exacto knife blades making templates, gages, and masks. The gaskets are always a good guide, but I've found that saometimes the gaskets need a little trimming as well, so they aren't an absolute perfect fit.
I usually save the playing card gages just in case one of the porting jobs works out exceptionally well. It would make a nice permanent template.
Old Oct 1, 2002 | 11:17 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Vader,
Do you think that my ZZ4 heads are that far off from the LT1 intake ports? The are the early corvette style w/ angle plugs.
Old Oct 4, 2002 | 09:24 AM
Vader's Avatar
It should be easy enough to measure and compare once the intake is off. At least intake removal on an LT1 is a little easier than a TPI.
Old Oct 4, 2002 | 06:48 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
You got that right. That was one of the reasons I didn't buy a Super Ram last year.
Thanks for all the help. :hail:
92projectcamaro
Jan 18, 2016 08:00 AM
86CamaroDan
Sep 29, 2015 10:08 PM
New2Chevy
Sep 28, 2015 12:35 AM
Jake_92RS
Aug 11, 2015 10:39 AM
