92 350 Roller Lifter Block
Old Oct 2, 2002 | 06:58 AM
LBSZ28BLOWN's Avatar
Car: Devastating Droptop
Engine: 355 Supercharged
Transmission: Auto 4L60, Built for 700hp
Do the late 350 Roller Lifter blocks have the same oil flow to the Rocker arms as the old non roller blocks.
I just built a 92 350 , I used the factory Roller Lifters with a
.520 int .530 ex lift cam Duration 220int 235ex 114 lobe seperation.
I get very little oil flow to the Rocker arms, is this normal.
and my valve trane is noisey.
I know old small blocks would shoot oil over the fender well at Idle.
My oil pressure is indicating 50psi.
Any thoughts
Old Oct 2, 2002 | 09:32 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I have the same situation with my 71 350 block. I have a ton of oil pressure, but it just drips off the top of the pushrods at idle. It's enough to keep everything well lubed, but you're sure not going to get any in your eyes.
Old Oct 2, 2002 | 03:47 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I have a 92 roller block & the oil oozes up the pushrods & runs down the rocker to the spring. Having it squirt all over the place seems counter productive. You need it where it will do some good, on the moving parts.
Old Oct 2, 2002 | 07:14 PM
Bort62's Avatar
Ive found the only time oil squirts that Much, Is when you Have the Rocker Too Loose.
Old Oct 2, 2002 | 08:06 PM
leirch's Avatar
My squirts the same, late model 350 roller block, new 383 motor , 2 bolt main, 50psi oil pressure. Same drip from pushrods. 7k miles on the motor, no problems yet that I can tell.
Well except for the centerforce pressure plate having a few cracks now... it just won't take a joke
Brendan
Old Oct 2, 2002 | 10:14 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
Just make sure you have some dripping across all the rockers, make sure none are dry at idle. Should get a good flow at around 1500-2000 rpms. If you are getting none on the rockers up front and you have good oil pressure, that could be an indication the the oil galley plug behind the cam gear on the block on whichever side is not getting oil may be leaking or has come loose. Thats rare but not impossible.
Old Oct 2, 2002 | 11:26 PM
Guest
Guest
Posts: n/a
Same oil flow.
MoJoe
Sep 24, 2015 09:12 PM
Mickeyruder
Sep 2, 2015 02:45 PM
camaro71633
Sep 1, 2015 10:24 AM
Eric-86sc
Aug 24, 2015 09:01 PM
