1le fuel tank
Old Oct 3, 2002 | 08:38 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
1le fuel tank
i was wondering when they started putting the tanks with the baffles like the 1le's have in all the cars. i have an 89 iroc and want to road race with it and am needing to know if i need the whole tank or just the 1le pickup?
and yes i already did a search.
thanks
anthony
Old Oct 3, 2002 | 09:25 PM
Bort62's Avatar
I was not aware they ever put baffled tanks in Anything other htan the 1LE's.
I don't think your going to have much trouble on the track tho W/o it.
You should always race on a Full Tank, Anyway.
Old Oct 3, 2002 | 10:02 PM
LYV18F's Avatar
gas is heavy...
Old Nov 3, 2003 | 12:44 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
I just picked up a tank out of a 91 GTA and it is definately baffled. The pickup looks different also, but and gaging that from memory when I changed my fuel pump last year. When I change my 87 tank out for this one I'll post pic of the sending units side by side to show any differences.
So, not just 1LE's that got baffeled tanks.
Old Nov 3, 2003 | 12:50 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
from what ive read.... in the YEAR 1990 regular production cars started getting the tanks regardless if it was 1LE or not...
im 90% sure that my 91 does NOT have it though...
Old Nov 3, 2003 | 02:26 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Sorry, i'm not a lot of help. This is one piece of thirdgen trivia that has slipped my mind over the years.
I just wanted to add before someone asks, there is no such thing as the 18gallon 1LE tank that you might see mentioned in some literature. Might even be in the FAQ of this site. If such a thing existed, noone has EVER documented it. The GM PN that you'll get if you look-up the gas tank for a 1LE car is the same PN they'd give you if you asked for a tank for a TBI RS. Normal capacity, baffled.
And as already mentioned, once the general went to baffled tanks, all cars got 'em. There could easily be exceptions if a non-baffled tank was left over in the parts pile that day though.
Old Nov 3, 2003 | 02:30 PM
rockind78's Avatar
I was under the impression that ANY multi-port injected car got baffled tanks as a matter of necessity. This is a big issue when retro-fitting older cars to modern EFI. Fuel slosh at less than a 1/4 to 1/2 tank can cause all sorts of stalling problems.
Old Nov 3, 2003 | 02:41 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
yup... and since my car isnt baffled, anytime its low on gas and i corner hard, brake hard, accel hard, or ESP when i brake hard and corner hard and then try to power out of a turn, it stumbles... i had it stall a couple times when trying to whip into the gas station too fast.... heh.
id love to swap some form of baffled tank in there..... athough id love to keep the tank full all the time too..
Old Nov 3, 2003 | 03:06 PM
alloy's Avatar
Car: 87 IROC-Z28
Well I looked for any 90 an up car to get a tank out of , GTA or otherwise. And this was the only one I found that was intact. Found a bunch of them at one yard, but their local laws require they either remove the tank completely from the car, or punch a hole it it. So, they had many tanks with holes in them, but not one good one. Too bad also. Would have been $15 and not $70 for it.
As to whether or not all 90 and newer cars got baffled tanks, I can't either confirm or deny that from my search for a replacement tank. I just know that this one from a 91 GTA did have a baffled tank in it. That's why I specified it was a GTA I got my tank from. I hope someone else with a standard car (not GTA-1LE) 90 and up pulls a tank to confirm they have baffles in them. For me my search for a fuel tank is over. Now just have to put the darn thing in.
Old Nov 4, 2003 | 10:07 PM
86_TA_LB9's Avatar
gas = ~ 6 lbs. per gallon...18 x 6 = 108 lbs...not too bad...
Old Nov 5, 2003 | 09:26 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
random 1/4 mile calc i used:
Car weight: 3500 lbs.
Horsepower: 300 hp
Configuration: Rear Wheel Drive
Results
Quarter Mile Acceleration: 14.325 seconds.
Terminal speed: 103.1907 mph.
Car weight: 3600 lbs.
Horsepower: 300 hp
Results
Quarter Mile Acceleration: 14.461 seconds.
Terminal speed: 102.2307 mph.
tenth in the 1/4 can be a big deal........
Old Nov 5, 2003 | 06:51 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
My 88 GTA is definatley not baffled... cut out quite a few times while close to "E" taking a turn. Now my 92 TA, that has never cut out nomatter how low the fuel.
Old Nov 5, 2003 | 07:01 PM
rockind78's Avatar
Maybe you thirdgens are somewhere in the middle??? I have read on numerous occasions with old cars converted to multi-port injection, issues were seen with as much as a little less than a half a tank. I'm thinking maybe your cars got some, but ADDITIONAL baffling after a certain year.
Old Nov 5, 2003 | 07:21 PM
alloy's Avatar
Car: 87 IROC-Z28
I'm the original owner of my 87 with TPI, and there is NO baffling in my tank at all. So it must be only earlier 1Le cars, and anything newer than 90.
Old Nov 6, 2003 | 10:08 PM
@ZZKKER's Avatar
wow, i figured this thread was dead.
anyway,
my 87 iroc did not have baffles in the tank, anything under a 1/4 caused the dreded right turn cut out. my 89 does have the baffled tank because i have run it as low as a gallon and a half at full speed while turning right with no cut out (i dont usually run it that low, the gas gauge said i had just under a hlaf a tank), so they must have started going to it in 89 or late 88.
thanks
anthony
Old Nov 8, 2003 | 08:46 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
Ok im gonna get a new tank for my car, and the idiots at gm dont know what im talkin about, so do u guys know the part number for a 1LE gas tank?
Old Nov 8, 2003 | 09:13 PM
alloy's Avatar
Car: 87 IROC-Z28
Well before you go to GM and start ordering parts, look at the price list in this thread for the parts needed for the conversion. Might be best to go hunt one down out of a junk yard like I did. Much cheaper. $70
https://www.thirdgen.org/techbb2/sho...t=baffled+tank
Old Nov 8, 2003 | 10:24 PM
onebinky's Avatar
If I remember right, my 92 RS L03 had the baffled tank. It's also been ~2 years since I had it down though, so I could be mistaken.
My 85 definately did not have them. I also never had a problem with fuel slosh causing the car to stall, but I also never let it drop below 1/4 tank for fear of overheating the pump
Let us know what you find out,
Matt
Old Nov 8, 2003 | 10:55 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
theres a rather good chance that the baffled tank superceded the orignal non baffled one for replacement.........
id order one for a 92 and look at what comes....
Old Nov 9, 2003 | 02:20 AM
@ZZKKER's Avatar
gm part number for the only fuel tank they list is 1026091. list is 440.15. that is for the 4cyl and 8 cyl. the 6 cyl is discontinued. what was said above about the new tanks supercieding the old part is most likely true.
thanks
anthony
mustangman65_79
Apr 14, 2017 05:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Glowsock
Aug 26, 2015 12:28 AM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
