Modding a L98 for HP not TQ?
Old Oct 6, 2002 | 07:08 AM
CrazyHawaiian's Avatar
Car: too many ...
I really want to swap a T5 into my B4C. Unfortunately the stock TQ rating on the L98 exceedes the T5's ratings. I was wondering how you guys would modify the L98 to focus on HP instead of TQ. I know some people have changed the intake to a LT1/StealthRam and end up with more HP, and less TQ. What other types of mods will give these kinds of results? The goal is to get as much HP as possible but not go higher than 330ft/lbs of TQ. Thanks for any help anyone might have.
Old Oct 6, 2002 | 07:42 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Even a mildly powerful 350 will have no problem making well over 330 pound feet of torque. The only way to make a 350 make less torque than that is to make it a complete wheezer with no power.
Instead why don't you concentrate on what people have run in front of T5s. Torque doesn't blow them up, abuse does. A basically stock L98 isn't going to pop a T5 unless you like 5k clutch dumps on slicks and powershifting....
Old Oct 6, 2002 | 11:03 AM
IROC57TPI's Avatar
*coughT56cough*
Old Oct 6, 2002 | 01:03 PM
jd13's Avatar
Ed pretty much summed it up. There is almost no way you're going to have a respectable amount of power out of that l98 and have under 330 lbs/ft.
If you don't abuse it, it will last...for a while or you could always go with the t56 too.
Old Oct 7, 2002 | 12:01 AM
Car: too many ...
Ok, lets change it then. Im a fool for thinking a T5 will handle my street racing antics considering the L98 is a torque motor. Say I stepped up to a T56. Those are rated around 425-450 ft/lbs of torque. Now what would you do with a stock L98 to get max HP but not exceede that TQ limit? Assume money was no object (it is, but I'm curious for ideas). What would be a choice N/A setup and what would be a choice F/I setup? Thanks again!!
Old Oct 7, 2002 | 12:19 AM
Bort62's Avatar
You will never break a T56 w/ a L98.
Old Oct 7, 2002 | 02:40 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
You can make L98 output 500+ hp N/A, add some power adders on top of that and I am sure you can tear a stock T56 to pieces.
Then again if you are willing so spend lots of money you can buy really strong aftermarket T56's but they cost lots of money, they used a t56 in vipers but it is a lot stronger then the ones that they use in the ls1’s
Old Oct 7, 2002 | 08:42 AM
IROC57TPI's Avatar
Theres a guy local around here, Matt Harlan that is in the 10's with a twin turbo'd LS1 Firehawk. All on the stock T56. Clutches seem to be weekend projects for him, as well as swapping from a 10 bolt rear to a 12 bolt.
Old Oct 7, 2002 | 02:25 PM
Bort62's Avatar
The T56 will stand up to Wheels up Launches running mid 10's all Day Long.
Its a Helluva trans.
500hp wouldnt even begin to test it.
Old Oct 7, 2002 | 03:39 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Bah.. T5 works fine here, after 3 seasons of brutal racing.
T5's dont blow up from torque or hp, they blow up from people who can't shift..
-- Joe
Old Oct 7, 2002 | 07:16 PM
Car: too many ...
Thanks for the vote of confidence Joe!
FormulasOnly
Jul 23, 2018 08:47 AM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
ssgt usaf
Sep 21, 2015 12:45 PM
