Throttle body rebuildable?
Old Oct 6, 2002 | 11:18 PM
88TAJeff's Avatar
Car: 88 T/A
I noticed some play in the throttle body linkage, enough to actually affect idle speed. I did a search and didn't find much. How do I get the bracket off that the throttle cable attaches to? Or does it come apart at all? I don't like the thought of getting a new one.
Thanks.
Old Oct 7, 2002 | 08:20 PM
88TAJeff's Avatar
Car: 88 T/A
bump.
Old Oct 7, 2002 | 08:27 PM
cobrakiller1989's Avatar
im not sure if its rebuildable or not, but if you want a temporary solution, i would suggest just getting a carb spring and hooking it to the TB and then drill a hole in the bracket that the linkage goes through and that will pull it back to where i belongs
Old Oct 7, 2002 | 08:36 PM
88TAJeff's Avatar
Car: 88 T/A
thanks cobra, (that 'bump' thing sure works) , the problem isn't the spring but the fact that the idle is going to be different every time that I stop at a light, or I get that annoying high idle sometimes. I also noticed that while I play with the throttle- just side to side that the TPS voltage goes up and down as well. That can't be good. I'm sure I can rebuild this thing but I don't want to screw it up. The end seems to be pressed on HOW DO I GET it off ?????
Thanks,
Jeff
Old Oct 7, 2002 | 08:47 PM
well you can buy a used one on ebay...they usually go for about $40 or so
italiano67
Dec 11, 2016 09:21 AM
hayesaw0210
Aug 23, 2015 11:15 PM
mdtoren
Aug 23, 2015 12:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mdtoren
Aug 16, 2015 05:45 PM
