is this true???
Old Oct 7, 2002 | 06:13 PM
cobrakiller1989's Avatar
is this true???
i have always seen that FMS injectors are rated at a lower psi than GM injectors and therefore when the pressure is raised up to wear GM's pressure or higher that it will make the lb/hr rate higher. is there any truth to this? I am thinking of getting the FMS 24# injectors and running them at like 48-50 psi. will that come out to like 26 #/hr if i do that? thanks alot
Old Oct 7, 2002 | 07:28 PM
Bort62's Avatar
Yes that is true.
okfoz
Oct 13, 2015 02:19 PM
mattcanty
Oct 12, 2015 11:08 AM
91 SrS
Oct 7, 2015 04:32 PM
paul_huryk
Oct 1, 2015 04:27 PM
Djmathis123
Sep 8, 2015 08:42 PM
