Can injectors be changed without removing the runners?
Old Oct 8, 2002 | 07:04 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
You would think that removing the runners is no big deal, but it is on mine because in order to get to the lower runner bolts I have to remove the valve covers. I have some custom removable top covers that are as wide as the head since the mounting bolts are on the inside of the cover then theres a removable top to the covers. Plus they are taller than the stockers.
So, I'm going to swap injectors this weekend and was wondering if it can be done without removing the runners?
Looks like maybe the driver side would come off without removing them, but not sure about the passenger side since theres an egr passage tube in the way on the runner.
Old Oct 8, 2002 | 07:41 PM
88TAJeff's Avatar
Car: 88 T/A
Yes it can be done. That's how I did mine cause I broke a torx bit inside a lower runner bolt. Those lower runner bolts are a PITA to get to anyway. the only thing is it's no fun fighting with those clips holding the injectors to the fuel rail.
Enjoy.
Old Oct 8, 2002 | 09:12 PM
2QUIK6's Avatar
Great, I will attempt it this weekend. Getting to the lower runner bolts with the old stock center bolt valve covers used to not be a problem usung a swivel head socket with the torx bit in it.
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
kyleb24
Aug 15, 2015 08:24 AM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
