'86 harness to '89
Old Oct 10, 2002 | 06:47 PM
87POSGTA's Avatar
Car: 1989 Firebird
Engine: 5.7 Vortec HSR
Axle/Gears: 9-bolt 3.45
'86 harness to '89
I just recently purchased a Stealthram ad went from an '86 harness to an '89. If anyone has a schematic for the harness it would be greatly appreciated. I no longer have A/C or smog equipment. and ive gone from in cap coil to a divorced. bit off a bit more than i can chew right now, work has all my time right now . plus i think ive got an auto harness when i have a manual.
ANY help i can get would be greatly appreciated.
Old Oct 10, 2002 | 07:25 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
i have scanned and placed engine wiring diagrams here. these are out of a chilton's book.
http://www.fl-thirdgen.org/wiringdiagram.html
Old Oct 11, 2002 | 06:57 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The 89 harness incorporates all of the non-engine plugs too, including headlights and all of that sort of crap. You can use it, but you've got to either splice it into your existing chassis harness, or remove it and put this one in as-is. If you're running an 87, then you'll also need to modify the alternator and air conditioning compressor wires because they're on the opposite side of your engine bay compared to an 89.
If I were you, I'd just keep the 86 harness. All you're going to need to do is change the distributer plug, but all 4 wire colors are the same, so it's not going to be the least bit difficult. That's the only change that you'll need to make to the 86 harness.
Old Oct 18, 2002 | 05:32 PM
87POSGTA's Avatar
Car: 1989 Firebird
K, well ive got the '89 Harness in my car and ive started to wire everything up. Now on both sides of the harness ive got a red and orange wire with weather-pak connectors on em. not quite sure what they hook upto. any ideas??
Old Oct 18, 2002 | 08:05 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
sounds like the power connections for the EFI.
Old Oct 18, 2002 | 08:25 PM
87POSGTA's Avatar
Car: 1989 Firebird
well my last harness, the '86 was all hacked to hell. I'll take a peek at my friends '87 Iroc and see if i can figure it out from there.
Old Oct 19, 2002 | 11:13 AM
Jza's Avatar
Jza
Yup, Saturn5 is right. Those power the whole harness (er well most of it).
Old Oct 19, 2002 | 06:06 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
I could be wrong, but you may have to repin the underdash connector as well.
Old Oct 21, 2002 | 08:28 AM
Jim85IROC's Avatar
No you don't. 86-89 uses the same ECM.
Old Oct 22, 2002 | 08:12 AM
Jza's Avatar
Jza
He may have been talking about the chassis connector(s) (the large clear one paired with the grey square one). That one will have to be repinned, and there's an extra connector that the 86 has which is not present on an 89 harness. This is because in 89 those wires were moved to the bulkhead connector.
Old Oct 22, 2002 | 08:15 AM
Jim85IROC's Avatar
Ahh. That's an issue that I was able to avoid by using an 87 harness.
Old Oct 22, 2002 | 11:28 AM
87POSGTA's Avatar
Car: 1989 Firebird
this swap is givin me a headache :lala:
KO1
16
Oct 15, 2015 05:00 PM
92firebirdchris
Exterior Parts Wanted
Oct 1, 2015 01:38 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
z28joe2
Sep 28, 2015 05:54 PM
Eric-86sc
Sep 28, 2015 11:37 AM
