Removing the Hardlines from the Fuel Rails
Old Oct 11, 2002 | 08:51 PM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
As the subject states, how would I go about removing the hardlines from the fuel rails or is it even possible?
Old Oct 12, 2002 | 02:47 PM
Guest
Guest
Posts: n/a
Its possible, but my understanding is that they are pressed in, and pretty much if you take them out you wont be putting them back in.
Old Oct 12, 2002 | 03:15 PM
rezinn's Avatar
You can separate the fuel rails from eachother by removing the horizontal bars, but I'm not sure about the front connection to the passenger side rail--never taken that apart before. There are o-rings between the horizontal ones and the fuel rails that you'll need to replace.
Old Oct 12, 2002 | 09:58 PM
Ions91Z28's Avatar
Hmm, they look like they are pressed in there rather well. The horizontal bars that is. Do I just pull on them to take them apart, if so, how about getting them back in. I'm bascially just trying to get the bars seperated.
Old Oct 13, 2002 | 12:27 AM
Guest
Guest
Posts: n/a
The horizontal bars (ones between the rails) are held in with small brackets that have a torx bolt. Other than that, its just o-rings holding those together.
Old Oct 13, 2002 | 12:46 AM
Ions91Z28's Avatar
thanks madmax, I must just be missing something. I'll play with them again tomorrow.
Andrew6.688
Dec 13, 2015 10:59 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
3rdgenparts
Aug 8, 2015 07:09 PM
92projectcamaro
Aug 6, 2015 01:20 PM
