which msd ignition for me?
Old Oct 19, 2002 | 08:54 AM
f0rmula350's Avatar
ignition is one of those things i know nothing about. as far as i know msd is the best ignition setup. which setup would i wanna use, i plan on supercharging my car within the next year. someone told me to go with the msd 6a ignition. thanks
chris
Old Oct 19, 2002 | 10:03 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
If you plan on running a blower, then you might as well go straight to the 6BTM. It has a timing retard function based on boost pressure. Worthwhile thing to have.
Old Oct 19, 2002 | 10:12 AM
f0rmula350's Avatar
would that ignition still be worh getting if i end up not putting a supercharger on my car?
Old Oct 20, 2002 | 10:20 PM
Ed Maher's Avatar
Car: 04 GTO
No. An ignition box is not going to help a NA car unless it's running a whole helluva lot of compression and rpms, etc. The money is better spent on basically anything else really.
Old Oct 21, 2002 | 04:11 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
An ignition box SHOULD "help" a litlte bit. It should make the motor run slightly smoother/more effieciently and as a result maybe give you a little better MPG. Results vary from car to car. This also may give you a little bit more throttle respsonse as well but it will not "make the car faster" or add any power whatsoever.
Will that particular ignition box help you if you don't supercharge it? An ignition box will still do the above stated but the feature of the 6BTM (the retard based on boost) will do nothign for you and a 6A will do the same thing. (I think you get the point, althought that was a little choppy - at work don't have time to edit)
Old Oct 22, 2002 | 08:59 AM
f0rmula350's Avatar
thanks for all the replies!
chris
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
meeklay812
Oct 1, 2015 03:46 PM
RedLeader289
Sep 23, 2015 06:50 AM
