Yanked the A/C, wiring auxilary fan to a switch?
Old Oct 21, 2002 | 07:05 PM
formul8!!'s Avatar
Car: 2004 GTO
I recently yanked the A/C out of my '89 Formula, and was thinking of hooking the auxilary fan to a switch.
After taking out the A/C, is that fan still functional and controlled by the ECM? Will a Hypertech fan switch work? I want to be able to switch this fan on manually.
Thanks!
Old Oct 21, 2002 | 07:17 PM
Jasper89ROC's Avatar
Hey Dylan, I got a Hypertech Fan switch too! I wonder what else I have laying around?
Old Oct 22, 2002 | 06:14 PM
richie rich's Avatar
If your settup is the same as a camaro with daul fans, over around the battery there should be two very large relays. One of these is for each fan. In order to turn them on you will have to determine which wire is the ground which is controlled by the ecm. On my car I believe it was a green wire but I can't remember for sure. Just cut the wire run a wire from the relay to your dash mounted toggle and anothe from the switch to a good ground under the dash.
Old Oct 22, 2002 | 06:59 PM
Bort62's Avatar
Your really Gettin serious about this 12.99 thing now
Run a wire to the Passenger compartment to ground out ( or power depending on how you like it ) the Secondary fan relay that Richie referres too.
That way you can flip it on whenever you want.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
355sbcTPI
Aug 19, 2015 04:38 PM
TA8487
Aug 16, 2015 12:21 PM
