plenum porting question
Old Oct 25, 2002 | 10:49 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
I know that the first place to start is right behind the TB,where those two walls are at the bottom of the plenum.This is the first time I have had my plenum off where I can see the inside of it . There is a hole on each side on the back ramp of the part that needs to be ground down.I assume it is like this on all plenums and when I grind this down,possibly elongating these holes, that this is not a problem,right?
Old Oct 25, 2002 | 11:03 PM
KNTA4DNU's Avatar
Car: '97 Z28
Engine: 5.7
Transmission: M6
Those are the EGR holes. The ramps are supposed to create a pressure differential that helps scanvenge the gases. If you just grind it down flat you shouldn't have any problems.
MantyZ28
16
Dec 21, 2015 11:02 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
mx127
Aug 10, 2015 08:13 AM
