Need help picking a TPI cam
Old Oct 27, 2002 | 10:11 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
I am looking for recommendations for a cam for a 350 I'm building (TPI). I'm going hydraulic flat tappet 'cause it's an older 2-piece rear main. I'm using a set of ported L98 iron heads matched to a Felpro 1206 intake gasket and an Accel intake maniflod ported to that gasket also. I also have 24# injectors and AFPR. I am expecting to get shorty headers and eventually aftermarket runners, too. Comp cams recommended part number 12-262-4 which, I'm guessing is an Xtreme Energy 262 cam. (Grind number CS XE262H-14)
Specs are:
Gross valve lift I-.464 E-.470
Duration I-262 E-270
Duration @.05 I-218 E-224
Lobe Separation 114*
My brother used a cam they recommended and was really disappointed with it and said I should take their recommendation and buy the next bigger one. Any thoughts???
Old Oct 27, 2002 | 10:35 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You mean its an older 2-piece rear main seal, right?
And you're gonna need a custom chip for that cam and the injectors as well, dont forget that.
I'd say that cam is fine for your mods. Any bigger and everything starts to be a restriction.
Old Oct 27, 2002 | 11:55 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Yea, 2-piece rear main (ok, I edited my post to now say 2 piece). And yes I will be needing a custom prom. Thanks for your input.
Old Oct 29, 2002 | 07:48 PM
91bluemetalicRS's Avatar
here is the cam I put in and I wish I would have went the next one up:
comp xtreme energy 08-502-8 (xr269hr)
gross valve lift .495 intake .503 exhaust
duration at .050 218 intake 224 exhaust
lobe sep 112
i am pretty happy with the cam but next year I'm going bigger
here is the site for ya. http://www.compcams.com/catalog/060_061.html
id say go with the xr276 cam I wish I would have put it in.
Old Oct 30, 2002 | 01:52 PM
TBurke's Avatar
R2Rs
That Comp Xtreme is a roller right? He is looking for a hydraulic flat tappet.
Iceman,
You would be happy with that cam im preety sure. I had a smaller cam 216 @ .050 lift 454 lift 110 lsa. It was installed with the new short block. It made tons of torque from idle to 5500. I had AFR heads/Superram/headers etc. I went low 13's all day on street tires. On the street, It would breaak em loose any time I punched it when it kicked in to 1st.
More is not better on a TPI when it comes to cams esp when you have a stock TPI. If you want another opinion call TPIS or Lingenfelter. Calling Copms was a good move.
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
masonta
Aug 31, 2015 10:14 PM
Sanjay
Aug 12, 2015 03:41 PM
