Largest Cam size with stock speed density?
Old Oct 30, 2002 | 10:43 PM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
Thinking about trying the TPI swap again...this time with a decent setup and with Vortec heads. I am mostly looking for a daily driver but may race occasionally. My question is will my cam run ok with no programming? Here are the specs:
Compcams duration: 212/224 lift: .480/.480 LSA: 112
I know the duration is a little high for stock EPROMs, but if it'll work, then I'm willing to give TPI another shot. Thanks.
James
Old Oct 31, 2002 | 11:10 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
The duration and lift won't be a problem but I've people have had issues tunning w/ the 112 LSA
Old Nov 1, 2002 | 05:38 PM
92TRANSAMWS6's Avatar
Well according to Comp cams catalog that cam requires a modified chip.
Part #08-300-8 is their stock TPI cam
Old Nov 1, 2002 | 08:43 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
The largest cam is around a 218 cam. BEFORE I got into burning chips I had a TPIS Level V chip custom burned for my 218/224 cam. The chip sucked. Eventually I got into PROM burning and I looked at what they did. They did nothing to the fuel curve. So - basically I was running stock fueling Anyhow - with stock fueling the 218/224 cam would bottom out at 108 BLMs but the integrator had just enough room to compensate. So - a 218 cam is borderline. Now, with that said, BEFORE the car enters closed loop and the ECM can compensate for the excess fuel at idle ... you'll be washing the cylinders with Fuel.
A 212 cam shouldn't be a big deal.
Tim
Steve78LT
Feb 24, 2016 12:15 AM
camaro71633
Sep 1, 2015 10:24 AM
Linson
Aug 21, 2015 02:12 PM
knight72
Aug 10, 2015 09:32 PM
86Base
Aug 8, 2015 01:34 PM
