TPI intake manifold
Old Oct 31, 2002 | 08:10 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
TPI intake manifold
I have an 89 Iroc TPI and forgot which years have the SAME intake manifold as mine from the factory. Thanks
Old Oct 31, 2002 | 09:22 PM
MrNova's Avatar
89 and up are the same. Before that has the cold start injector provisions.
Old Oct 31, 2002 | 09:41 PM
rockind78's Avatar
If you are referring to the base intake manifold, '87-'92 is what you have.
Old Oct 31, 2002 | 10:11 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
So I need an 89-92 base since the 88-earlier had cold start injectors.
Thanks.
Danny T
Old Oct 31, 2002 | 10:47 PM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
rockind78 is right, 87 and up is what you should look for. The only differences between lower intakes are the centerbolt vsm perimeter style heads.
Old Nov 1, 2002 | 07:33 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The cold start injector does not impact the base... only the runners and plenum.
Old Nov 1, 2002 | 11:35 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
OK, thanks for the help
Danny T
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Jake_92RS
Aug 11, 2015 10:39 AM
