New timing with Alum.l98 heads?
Old Oct 31, 2002 | 08:25 PM
Abubaca's Avatar
OK, with the higher compression, the timing would need to be advanced right?
Would a chip from corvette handle that, or is just better/easieer to do it by hand.
Oh, and are the vette heads and the zz3 heads the same casting #
Old Oct 31, 2002 | 10:00 PM
Guest
Guest
Posts: n/a
You may not need more timing, it might run better with less. Just try it at different places, see what works better. Without reprogramming you're kinda limited, but just changing the base timing can help.
midge54
Dec 27, 2019 04:14 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
ZsTransAm
Aug 11, 2015 07:30 PM
