vaccum lines ?
Old Nov 3, 2002 | 07:49 PM
pokes87iroc's Avatar
vaccum lines ?
ok i dont really care about emissons so what vacum lines do i really need and what ones can i plug up. pics would be great thanks for any help
Old Nov 4, 2002 | 12:11 PM
Vader's Avatar
If you're still running the stock ECM on your TPi, about all you can do away with and not affect the ECM is the brake booster and HVAC controls, possibly the cruise control.
* The ECM requires an operating EGR, since the diagnostic temperature switch needs to react when the EGR is commanded open.
* You could eliminate the AIR management valve and its lines, but the O² sensor will not heat as fast, taking longer to achieve closed-loop. This can be remedied by installing a HO2S.
* You could also eliminate the FPR vacuum line, but you would constantly be running rich at low load and probably lean at WOT.
* You could eliminate teh PCV valve, but the engine will begin to build sludge deposits within a few weeks driving.
Other than that, disconnect whatever you want.
Later,
Vader
All my life I've been searching for something. Something never comes - never leads to nothing...
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
romcjr
Sep 17, 2015 05:18 PM
TBRays98
Sep 6, 2015 05:05 PM
rjcme
Sep 5, 2015 01:23 PM
