Turbo for TPI???
Old Nov 9, 2002 | 06:10 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
Turbo for TPI???
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1871030331
This custom built or something.... I thought they did not exist.
And how would it work on a completely stock car with no SES?
Old Nov 9, 2002 | 06:24 PM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
There are SBC turbo manifolds floating around, which is what he's using. Everything else is custom brewed. If everything was hooked up correctly there wouldn't be any reason to set a code.
Old Nov 10, 2002 | 12:35 AM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
Many companys build addon turbos. Minimum price is around $5,000.00. $1500 is a steal for bolting on about 150 HP with stock setup. Your 383's HP would probably be more even with stock TPI. You would however need a new prom. I see the auction has ended. Since no bids were entered, you can by Ebay rule make an offer at minimum bid to the seller.
Old Nov 10, 2002 | 02:01 AM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Man... the power that would produce on a ZZ4
Terrell351
Jun 13, 2021 01:13 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
