Is it possible to from carb to TPI(LT1 intake) for $1000
Old Nov 13, 2002 | 04:04 AM
Zio7's Avatar
Hey guys I am doing some research for a friend. I know a little about fuel injection considering i own a 95 formula. But i don't know much about TPI. My friend has a 76 pickup with a 350 that is built up. He is looking for a little more streetability, so he is looking into TPI. Now he wants new runners and everything because this motor is going to be pushing 375hp. His friend is going to sell him a complete TPI system (comptuer and everything) for $350.
Here is what I need to know.
Would it be better to buy new runners and intake?
or
Buy the LT1 intake that fits the TPI?
I am thinking for the price the LT1 would be better, but you guys tell me.
Also whatever one you think is better, what would he need to do it? I need specifics because we are kind of lost on this subject. Would he need an after market wiring harness considering he has the comptuer and everything already?
Also he wanted to run camel hump/double hump heads will they work?
Basically i need to know everything that needs to be done to covnert and which way is the better way (makes more power)
And is it possible to do this for around $700 (not including the purchase of the TPI system)?
thanks
Tom
Old Nov 13, 2002 | 09:34 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Stock TPI isn't much good for making power. Depends on what you're going for. Done well you can get near 300hp and big block torque out of a stock TPI set-up.
The LT1 intake will make a smidge less mid range torque but a lot more power. Some people have been having problems with the LT1 swap though, so i'd do my homework before i made this leap.
As far as what to do with the rest of it, you can get a 730 speed densty ECM for under $50 from ebay or junkyards. They came ina lot of different GM cars in tha late 80s / early 90s, like the FWD V6 corsicas, berettas, etc.
As for a harness, and aftermarket harness would probably be the easiest way to go since emmisions probably aren't a concern on a 76 pickup truck (aftermarket harness won't have charcoal canister purge, or air diverter controls, etc) If you already have a harness and electrical ability (also known as having a DVOM and basic problem solving skills) you could probably convert and use the one you have for whatever you need to.
Other than that all you need is high pressure fuel pump, feed and return lines. And a throttle cable.
Old Nov 13, 2002 | 01:26 PM
Zio7's Avatar
I know this is a stupid question, but why would he have to by another ECM? He is getting the ECM with the TPI setup. If it matters the TPI came from a transam.
So what he would need is:
Lt1 intake
aftermarket harness electric fiel pump
Fuel pressure regulator
Also do you think the TPI would make as much power as he is now with a 650 holley? Would the streetability be much better?
thanks
Tom
1992rs/ss
Jan 31, 2025 05:10 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
