Right side cooling fan always on
Old Nov 13, 2002 | 11:02 AM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
One of the two radiator cooling fans (right side) is always on. Comes on when you turn the key on and never goes off.
If this a realay problem, or something in the chip? The chip is one from Turbo city we bought around 10-11 years ago. This car never warms up fully, which in the summer is ok, but it would be nice for it to warm up fully so the heater would work better and the engine would be at it's proper operating temp.
Dan
Old Nov 13, 2002 | 01:45 PM
Dustin Mustangs's Avatar
Car: I
Engine: Taunt
Transmission: Mustangs
On the passenger side head is a fan switch that grounds a single green wire when it reads a certain temp, which turns the passenger side fan on. I would guess that either this switch has failed, or that wire has shorted somewhere else. I have mine grounded to the the engine on purpose to keep that fan on all the time. This helps keep my temp were I like it in the summer, but as you said, cold temps make my car take too long to heat up when wired this way.
Old Nov 13, 2002 | 01:52 PM
alloy's Avatar
Car: 87 IROC-Z28
Thanks for the reply. I'll pull the wire and see if the fan stops. If it does then the switch is bad, if not then I've got a grounded wire.
Ikes 91Z
Dec 9, 2015 03:49 PM
krisner89
Oct 10, 2015 06:03 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
