Serpentine Belt Q
Old Nov 13, 2002 | 07:29 PM
SCCAjunkie's Avatar
Car: 84 Z28
Engine: 91 L98 long block with Pro-jection
Axle/Gears: 91 10bolt w/ 3.42s and T2R
Serpentine Belt Q
OK, here's the deal...
I want to get rid of my A/C and air pump. How do I route the belt to do this? Do I need some type of A/C idler pulley? the 1LE A/C eliminator setup? Also, I am installing a UDP (possibly) so will that have any effect?
Thanks in advance for any info...
Please email direct, as I do not get in here all the time (can't access thirdgen.org from work- DAMN!)
Matthew A. Green --- mattgreen*remove*@msquaredracing.com
M"squared" Racing! --- http://www.msquaredracing.com/
85 Shelby Charger- 260hp, no waiting!
87 GLHS #314
90 Formula 350- I think I'll have a V8!
98 P-Neon SOHC- ACR wanna-be
01 Ram Off-road- Something has to tow all this stuff!
Old Nov 14, 2002 | 10:27 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
http://para.noid.org/92z/pictures/?m...ze=800&start=0
This is a picture of what Nick Steel did. You have to measure the
length pretty
exactly (piece of string) , but going around the crank,WP, adjuster,
Alt, and P/S
in this fashion will get things all turning in the correct direction.
mike
Old Nov 14, 2002 | 01:06 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
In the tech articles section of this site you'll find everything you need to know.
you'll need an a/c delete pulley and a slightly shorter belt. the length and the part number is in the tech article.
Old Nov 14, 2002 | 10:41 PM
11SEC91Z's Avatar
Car: 91 Z/28
Engine: 6.3 L98
Transmission: TH350 4500 STALL
Axle/Gears: 3.73s
85MikeTPI..would you happen to know the size of that belt in the pic?
Old Nov 15, 2002 | 06:54 AM
85MikeTPI's Avatar
No, sorry.. It should be measured anyway
because of UD pulleys, and different tensioner
spring tensions.. It shouldn't be hard to do
with a piece of string and a friend... 8-)
Note: I forgot to mention that belt life will be
shortened with this method, because the ribs
of the belt ride on the tensioner, instead of
the flat back side of the belt..
mike
Old Nov 15, 2002 | 11:08 AM
Guest
Guest
Posts: n/a
I think the belt life might be ok, I'm running a setup on another car like that, except its the ribbed part of the belt against a flat water pump pulley. Not seeing any black dust, and the belt has been on there at least 20k miles. Dont see any sort of wear.
Take note of his upper radiator hose with that belt routing. You'll need to address that.
Old Nov 15, 2002 | 11:41 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
On my setup the flat side of the serp belt rides on the tensioner. If you route like it's routed in the tech article you'll be fine.
jrdturbo
Mar 31, 2016 02:58 PM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
SRKLEGIN
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
