runner bolts
Old Nov 15, 2002 | 09:47 AM
Brian'sIROC's Avatar
runner bolts
Whats the thread size for the runner bolts on a TPI setup? I stripped one of the torx last night, and plan on replacing them all with allen head bolts.
Old Nov 15, 2002 | 10:32 AM
Vader's Avatar
The bolts are M8x1.25.
If you use hex-socket ("Allen" is a proprietary brand name of Holo-Krome) try to get cheese-head cap screws. Don't laugh, becuase that's what they're called. They are a lower profile, broader head cap screw, just like the originals.
A standard socket cap screw does not have enough bearing area under the sholder. If you have to use regular socket cap screws, you'll also have to get hardened washers to distribute the load so you don't stress crack any of the castings. 5/16" hardened washers will work fine if you cannot find 8mm washers. You'll also have to consider the slight length differential caused by the washers, and the extra head height, so trying to find the cheese-heads is worth your time. If you have a Service Supply or Fastenal distributor in your area, give them a call.
Old Nov 15, 2002 | 11:12 AM
Are cheese head screws the same as button head screws?
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
toronto formula
Sep 10, 2015 07:31 AM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
