Need help on TPI question
Old Nov 21, 2002 | 04:52 PM
Steve-o's Avatar
Can someone take a measurement on thier TPI plenum for me? I need to know how far it is from the throttle body mounting surface(front of the plenum) to the top bolt that holds the throttle cable bracket. I am working on a custom intake and I need to know where to mount the throttle cable bracket in relation to the throttle body. A pic would be great if you have one. Thanks Steve
Old Nov 21, 2002 | 08:11 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
A custom intake... neato!
sorry im of no help with this post, i just think its cool youre gonna make your own intake, thats badass.
Old Nov 21, 2002 | 09:35 PM
Steve-o's Avatar
I'll post some pics when I am all finished. Its based on a tunnel ram lower half with the plenum machined off. It has a custom made plenum with a 58mm throttle body on front. Its plumbed for injectors and and all of the vacuum ports are on the back of the plenum so it is completely smooth. I am usinf a Lokar bilet throttle cabel bracket and Lokar stainless cables. I am using a 92 TPI computer with a custom burned chip by S&P and a harness that I made. I am using 30 pound injectors becasue it is on a 454. The motor is in a 57 Chevy Nomad. The car and the injection is about 98% done I should be ready to fire it up in about a week and a half. Thanks Steve
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
