MAF SEnsor????
Old Nov 23, 2002 | 10:19 AM
Cloud VF102's Avatar
MAF SEnsor????
WEll I'm having a little trouble it seems i get a code 34 for the MAF sensor, I just bought a new sensor so maybe it's off....I do notice that when my engine is running the fuel pump whines the whole time, maybe that could be the MAF fuel sensor instead of the maf or what could my problem be
Old Nov 23, 2002 | 03:04 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Could be a bad relay, causing the MAF error.
I don't think the FP whine is a cause of the code 34, but may still need attending to.
Old Nov 23, 2002 | 05:27 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Did you replace your MAF immediately before getting that code? If so check the MAF. If not try the burnoff relay on the firewall/driver's side.
Old Nov 24, 2002 | 12:14 AM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
code 34 is tricky.. not always is it the maf sensor. check all of your vaccuum lines. i pulled a code 34 for liek 3 months, my maf was fine though i tested it out on another car. one of my vac. lines going into the block had a large tear in it.
Old Nov 25, 2002 | 04:49 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Do a search for code 34 and you will find alot of info/tips. My code 34 disapeard when I raised my TPS a litte.......
BumpaD82
Feb 26, 2016 02:57 PM
sleprock
Oct 1, 2015 09:39 AM
Racerx974
Sep 19, 2015 10:16 AM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
earlpote
Sep 12, 2015 11:55 AM
