Knock Sensor Question - urgent!
Old Nov 23, 2002 | 04:45 PM
CarAteMyMoney's Avatar
The car is an '86 Vette.. I saw there is no wire on the knock sensor but there are a few wires dangling nearby. What color wire goes on the knock sensor?
Also which wire goes on the coolant sensor on the drivers side cylinder head? Green right?
Old Nov 23, 2002 | 05:57 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Welcome to 3rd gen.org...the home of Camaro's and 'Birds...not Vette's
If noone replies, I'd suggest searching the Vette Forums for your answers. Good luck.
Old Nov 24, 2002 | 11:43 AM
Hey moron,
I've been on here for years as another name but forgot my password. I had an '87 Camaro, '88 L98 Iroc, and '89 ASC GTA, and TPI is TPI whether its in a camaro, vette, or even a '32 Ford..
so if you can't answer my question, please refrain from comments
Old Nov 24, 2002 | 12:10 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Geez, and I thought I was being helpful. The was no malice or flaming in my reply, nor none intended.
Also, I believe on my '89 it's white
Old Nov 24, 2002 | 05:07 PM
no problem. Did it also have a metal tab with a mounting bolt hole a few inches from the connector? Cuz that's dangling around along with another dark wire
Old Nov 24, 2002 | 10:59 PM
rezinn's Avatar
I want to say white as well, and the cts wire is green. I'm not sure what you mean by the bolt hole, but last time I checked the wire(when it wasn't hooked up on my last engine, heh), it had some kind of pointed metal thing on the end of it. I think it pulled out of the sensor when I changed my starter or something. If that other wire is black it may go to the fan switch.
Old Nov 24, 2002 | 11:23 PM
OK from what I read the CTS should be near the throttle body. There's another coolant sensor on the drivers side of the engine, and there's a green wire which i'm told is a fan switch. It's in teh same split loom tubing as the fan's power wires.
In other words, i'm still baffled.
Old Nov 25, 2002 | 01:23 AM
rezinn's Avatar
Sorry, by cts I meant sender not sensor. The green wire is for this on the drivers side head, it runs the temp guage in the dash. The black wire on the passenger side is for the fan switch, also in the head.
Old Nov 25, 2002 | 01:30 AM
kingrobert's Avatar
I would say white as well, but if it doesn't help you can check out www.scfyb.com or http://pub21.ezboard.com/bscfyb, they don't discriminate against corvettes
Old Nov 25, 2002 | 06:06 AM
nitrovette's Avatar
Car: 73 corvette
Engine: 2004 ls1
knock sensor wire is white and fan switch is green
bamaboy0323
Sep 3, 2015 06:07 AM
db057
Aug 22, 2015 08:17 PM
redmaroz
Aug 16, 2015 11:40 PM
gwade12
Aug 8, 2015 08:17 AM
