Max lift on stock heads is .440?
Old Nov 23, 2002 | 09:21 AM
Nasty_Bird_'90's Avatar
.Huh?! I just got my heads from the machine shop last night and they told me the highest lift cam I could use would be a .440. I thought the stock heads would take .480? Should I have the seats ground down? I've got the comp 08-302-8 that has .480 lift but now I'm afraid to put it in.....
Old Nov 23, 2002 | 09:22 AM
BTW, I plan on using a set of LT-4 springs too.
Old Nov 23, 2002 | 02:29 PM
89BlueTA's Avatar
The machine shop I used said that the heads would only clear .460 lift, so it probably justs depends on how much clearance they are calculating.
Though normally if they have to cut the seat for a bigger spring the valve guide will get cut at the same time.
It should not cost very much at all to have the guides cut down.
nick
Old Nov 23, 2002 | 10:08 PM
Shagwell's Avatar
Car: projects.......
Cut the guides, should be cheap. - CP(competition products) sells the GM HP Z28 valve spring kit(easily safe to .510) for $29.95. The kit has the springs, retainers, and locks. - just my $.02.
later, justin...
Old Nov 24, 2002 | 09:44 AM
Thats cool, but how does just a spring with the stock guide height increase the lift?Are the springs taller to increase the distance between the retainer and the top of the guide? Regardless of the spring's tension, this is what ultimately detirmines the max lift.
Old Nov 24, 2002 | 10:58 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
The spings tension and installed height determine max lift. Go to the comp cams catalog and look at their spring chart. You can have 2 springs with the same diameter and height, but have different pressures because of the spring rates.
Old Nov 24, 2002 | 06:14 PM
So how exactly do I detirmine how much lift the heads can handle? Are the aftermarket springs taller than a stock spring? I plan on using a set of LT4 springs with a comp 210/220 .480"/.480" cam.
Old Nov 24, 2002 | 08:02 PM
Shagwell's Avatar
You sill need to cut the guides down a little. I said that and the springs, because you don't want to have any valve float. If you push the vavle open further, and the spring isn't stong enough to close it any quicker, you will have valve float, which is death to cylinder heads. Comp and Crane make a tool that you can put in you drill to cut the guides down. The Comp part # is 4726. Thier vavle seat tool is 4718. The Crane part # 99402-1, but I think you also need 99027-1 to do all the work(not sure about the crane tools) -
later, justin...
Old Nov 24, 2002 | 08:49 PM
Thank you all for all of your input. I think I'm gonna take them to the machine shop to have the guides cut down quite a bit. Thanx. :hail:
Old Nov 24, 2002 | 09:05 PM
e-man's Avatar
Car: 89 formula
Engine: 383
I used the same comp cam in my old 350 and only changed the springs with my stock heads.I had no problems with the retainers hitting the guides.I guess I was just lucky
Old Nov 25, 2002 | 12:18 PM
Damon's Avatar
I just went through this recently on a set of L-98 castings. There was contact between the retainer and the valve guide seal at .475". You should NEVER run valve lift right up against that spec unless you want the occasional valvetrain breakage or enjoy replacing vavle guide seals every few months. I wouldn't have run anything over .455" lift on these heads without machining the guides down. Every head is a little different, though, so a blanket statement can't really be issued. Gotta measure and see for yourself.
The springs would have taken more lift- they were not the reason for the "top stop."
theshackle
Mar 5, 2017 06:37 PM
gta90
Sep 15, 2015 04:00 PM
NWAsonoma
Aug 18, 2015 05:45 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
anesthes
Aug 8, 2015 09:37 PM
