newdistributor for LT1 conv...
Old Nov 25, 2002 | 07:55 PM
gflo383's Avatar
Car: IROC Z
Engine: 355 MINIram w/boost
if i get a distributor out of an 87 roc, so it will fit with the lt1 intake conversion, how do i wire it, isnt it different style connections? also, is the distributor from any v8 external coil GM gonna fit? cuz the one in my 89 chev truck has a dist. that looks the same as the 87+ f body's... thanks for any advice/comments, JOE
Old Nov 25, 2002 | 09:55 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Yes, you can and should use a distributor from a '87+ Camaro.
The connectors are differant but the wire colors are exactly the same.
You can pick up replacement connectors from Pep Boys. They come with some wire already on them.
You can also use a truck distributor as long as it looks exactly the same, two connectors in the back and no vacuum advance.
Old Nov 27, 2002 | 11:35 AM
gflo383's Avatar
Car: IROC Z
thanks John, you are da best! by the way, how long does it take for you to mod the LT1 intake? i will be sending you one in the next couple of weeks, just curious.
Old Nov 27, 2002 | 07:47 PM
Engine: 4.0L
Average turn time is 3 weeks, sometimes 4 weeks.
Old Nov 27, 2002 | 07:59 PM
gflo383's Avatar
Car: IROC Z
Damn, thats a long time, i better get this out to ya....
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
