what sort of 1/4 mile times should i get
Old Nov 25, 2002 | 08:41 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
i have a 1987 with a l98. over the winter i plan on puting a set of afr 190 heads on it at the same time i am going to go of the deep end on the intake. by off the the deep end this is what i plan o doing. i plan on cuting the runers in half and making one big runner out of each pair of runners then i am going to port the hell out of the base to more or less make it into a single plane.
so after i get done with all of this what am i probaly looking at in terms of horse power ,torque and 1/4 mile or should i get rid of the maf and go map befor i start.
Old Nov 26, 2002 | 10:46 AM
c4boom's Avatar
Engine: l98 and lo5
know one has ever run a set up like this? is there any thing that i an add that would help? are the runners going to be to much?
Old Nov 26, 2002 | 11:18 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
cam? Torque converter? PROM burning?
Old Nov 26, 2002 | 12:09 PM
c4boom's Avatar
Engine: l98 and lo5
i will be using a 276hr-14 comp cam it has 220 int, 230 ex at .05 and .510 lift on 114 lsa
the converter i am looking at is about 2000 rpm stall with lockup
i would like to not have to burn a prom for it due to the fact i will pbly be installing a accel dfi but if i cant scrap up the cash will it run on the stock prom with the maf
Old Nov 26, 2002 | 01:03 PM
Ed Maher's Avatar
Car: 04 GTO
With the right converter, tune and a little luck, you could make it way into the 12s on such a thing.
Without those, mid 13s wouldn't surprise me.
If you're actually trying to go fast, you're going to need a lot more than 2k of stall in the converter for that combo.
Old Nov 26, 2002 | 02:00 PM
c4boom's Avatar
Engine: l98 and lo5
i have not delt with lockup converters much how much stall can i go befor the thing starts to burn it self up on long trips i know any thing over about 2500 on th350 with 3.56 will kill the trans temp.
Old Nov 26, 2002 | 02:53 PM
Ed Maher's Avatar
Car: 04 GTO
I have a 3k stall behind my stock 305, and it was daily driven for probably 12-15k miles like that for a while until i recently bought a new driver. There really is no limit to how much stall you can run with a modern good quality lock-up converter like a vigilante or yank. Modern design are so efficient that they can still be reasonably tight in light throttle driving, but as you crack the throttle you get into the stall. And during cruise the TCC is locked so you don't have any heat issues whatsoever.
Old Nov 26, 2002 | 03:06 PM
c4boom's Avatar
Engine: l98 and lo5
so i could run a 3000 stall and it would still be ok on the high way that is so cool so there is a hope for me yet to get in the 12's all i want to be able to due is keep up with a ls1 car but it will be nice if i can pass one.
Old Nov 26, 2002 | 07:03 PM
MdFormula350's Avatar
yeah those ls1's are quick, it would be nice to beat one some day
Old Nov 27, 2002 | 02:18 AM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
I run a 3200 stall lock-up Yank converter. I've put at least 20k on it since when it was my daily driver, never a hint of a problem. stop light to stop light, highway, track, handles them all like a charm.
Old Nov 27, 2002 | 10:30 PM
Nasty_Bird_'90's Avatar
Hmmmm, Yank convertors. It hasn't blown up yet? Very surprising. You shouldn't have to worry about a 3k blowing up the tranny on long trips, 'cause it's usually locked up when you're on the highway anyway. A tranny cooler and a temp gauge are always good ideas though. Highly reccomeded. When choosing a convertor, you need to look at more than just the stall speed. You need to look at the STR of it as well. The ratio affects how the car launches and how it acts in the top end. If you want a good convertor that will blow away any Yank or TCI, let me know. We have a guy that custom makes them for us and he'll customize it to your application. PM or email me if you like. BTW, you only need a 12.90 to take all the stock LS1 T 56 cars on the road. I've never seen a stock one go any faster than that, and I work on them all day.
Old Nov 28, 2002 | 07:13 PM
c4boom's Avatar
Engine: l98 and lo5
so with all the mods and a 3000 stall i might be able to pull low 13 high 12 dam makes me want to just build all forged lower end and just spray the snot out of it i was hopen for mid low 12's
Old Nov 29, 2002 | 07:34 AM
CHRISMAN2000's Avatar
Car: 1991 Camaro Z28
Engine: 350 L98
I think to save time you should just give the 190's to me.
Good luck with your set up.
Old Nov 29, 2002 | 09:45 AM
Ed Maher's Avatar
Car: 04 GTO
The stock intake is what would end up limiting you with that combo. Everything else is in place to get somewhere, but you can't trust stock TPI parts to really make that kind of power.
Old Nov 29, 2002 | 09:55 AM
c4boom's Avatar
Engine: l98 and lo5
i fergot to say that the intake that would be geting the port job is a big mouth
Old Nov 29, 2002 | 09:43 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Well if you actually improve the runners with the frankenstein project (good luck on that btw - should be interesting) and port the BigMouth I don't think it'll be very restrictive save for the stock upper manifold. Port that too!
Old Nov 30, 2002 | 04:07 AM
Engine: 350 L98
Don't forget to port match.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
evilstuie
Jan 9, 2020 08:29 PM
Linson
Aug 21, 2015 02:12 PM
