modified 305 ideas
Old Nov 25, 2002 | 09:32 PM
TPItransam85's Avatar
modified 305 ideas
well i got an 85 trans am 305 tpi and im running a 15.1 stock and now i got a hooker catback and im planning on getting headers and a cam and lifters and christmas is coming and i need some ideas for some mods im looking for the best solution what do u guys think.
Old Nov 26, 2002 | 08:51 AM
Hodge's Avatar
Car: 1987 IROC-Z28
Engine: 383 Vortec - carb
Transmission: T56 - 6speed
aftermarket coil and some good wires.
LT1 intake
Old Nov 26, 2002 | 10:25 AM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
Re: modified 305 ideas
im not sure if a new cam is really what you need, you already have a somewhat decent one. You should consider switching to the newer ECM and get into prom burning. I havent done it yet, but that will be my next step, that 85' ECM sucks. other than that, upgrade ignition, headers, move battery to rear... stuff like that.What gears you have? got posi? then u should be ready for a cam. Im kind of interested in how you do as i have a relativly stock 85' TPI car as well.
Old Nov 26, 2002 | 11:48 AM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
First off everyone here is going to say dont bother with the 305 because there is no replacement for displacement. I now have to agree with these people. I have a 305 in my car now that with a few mods runs in the mid to low 14's no problem. I have now ditched the idea of building it up for a 355 so now I am buying parts that will swap over. So with that said if you plan on doing a motor swap I would say buy parts that are going to work on a 350 like headers, cat, cat-back system (3"). Then like stated above new igition system (coil, plugs, wires, cap/rotor, MSD box), if you feel like it gut your MAF (some say it does nothing though), you can do an AFPR, airfoil, and then I would personally dive into the suspension. STB, SFC, LCA's, Panhard Rod, Torque arm, that way when you do get the power you will actually be able to use it and not just go up in smoke.
As far as relocating the battery, dont. It is going to do nothing for you but cause headaches unless you are going to be doing nothing but dragracing. But that is just my opinion. Good luck and happy motoring.
Old Nov 26, 2002 | 05:34 PM
what he said
Old Nov 26, 2002 | 07:08 PM
iroc_cragg's Avatar
Yeah. If u plan on adding a new engine dont bother wasting money. I have a 1985 IROC with a 305 TPI that I am gonna be moding this winter while its in storage. I am going to be getting a 355 or 383 built so Im not gonna waste to much money on the engine, Just get bolt ons and other stuff that u can transfered over. U can get a quick TPI with Headers, Catback, K&N filters along with the gutted MAF and the free mods. Then add on some suspension stuff, and a better Torque converter. Thats should get u to where ur happy.
I have heard about some guys putting the LT1 cam into there 305 TPIs and getting some good results, U can get them used for around $50 bucks. I am pondering this idea, I might go ahead and do it but I havnt heard to much, Im trying to get more info on the topic.
Also look around at other guys cars on here and take a look at what mods they have done to there 305s. Some guys pull some inpressive times with them.
Good luck.
Old Nov 26, 2002 | 09:31 PM
Ranbo108's Avatar
Car: '85 Z28 TPI
Engine: 305 F vin
Transmission: 700
Axle/Gears: 3.23 posi 10 bolt
Well, like I said in my TPI post, does anyone know the TPS voltage for an '85 Z-28 TPI? I'm stuck with the 305 at least for a while. Thanks, Randy
Old Nov 27, 2002 | 04:01 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
0.54 volts
Old Nov 27, 2002 | 07:07 AM
Ranbo108's Avatar
Car: '85 Z28 TPI
Engine: 305 F vin
Transmission: 700
Thanks much!
Old Nov 27, 2002 | 08:14 AM
camaro6spd's Avatar
zz4 cam
headers
cat-back
ported head and intake
should net high 13s in a 5 spd
Old Nov 27, 2002 | 11:06 AM
Good luck.
too bad you can't use an LT-1 cam in you engine.... the 85' is a non-roller block
Frozer!!!
Jan 19, 2024 04:55 PM
NinjaNife
Aug 23, 2015 11:49 AM
GouldyGTR
Aug 21, 2015 10:43 PM
theurge
Aug 21, 2015 12:46 PM
marcusaw
Aug 10, 2015 08:13 AM
