any difference??
Old Nov 30, 2002 | 06:33 PM
Kandied91z's Avatar
any difference??
in the tpi runners and plenum between ta and camaro as well as through the years........? weren't they all the same. someone keeps trying to tell me the aren't and i'd like someone else's opinion
Old Nov 30, 2002 | 06:41 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
All TPI units of similar years are the same regardless of model. 88 and earlier had 9th injector (cold start).
Old Nov 30, 2002 | 06:45 PM
Kandied91z's Avatar
thanks, that's what i thought!
Old Nov 30, 2002 | 10:03 PM
Z_Ghost's Avatar
90 to 92 plenums have the passenger side drilled and taped for the map sensor, 89 and older do not have this done to them.
Old Dec 1, 2002 | 02:42 AM
Kandied91z's Avatar
thank you.........now that was something i over looked.
is there anything else?
Old Dec 1, 2002 | 10:59 AM
jms's Avatar
jms
The fins on top of the plenums changed***I believe*** in 1989.
Prior to '89 they extended farther on the top of the plenum. In 1989 (I think thats the year) through 1992 used fins that were about half the length of the earlier versions.
jms
Old Dec 1, 2002 | 01:57 PM
MdFormula350's Avatar
minor differences, however different enough to make sure you get the right ones for your year of engine/car..
Old Dec 1, 2002 | 02:02 PM
Kandied91z's Avatar
are you guys absolutely sure............the ones i have sitting in front of me look to be off of a 92, yet they look identical in everyway cosmetically to my 91?
69GTOby
Apr 18, 2016 02:34 PM
BAMiller
Sep 14, 2015 06:38 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
