What Cap/rotor to get
Old Dec 2, 2002 | 09:37 PM
91 z28 350's Avatar
Car: 91 Z28
Ok i want to get an accel cap/rotor kit but what style ignition did our cars come with the HEI ?? Im going to order the accel cap and rotor from summit so which part number should i get if any one knows ?
Old Dec 2, 2002 | 09:47 PM
91 z28 350's Avatar
Car: 91 Z28
Never mind found it on jegs they give better discription
Old Dec 3, 2002 | 08:52 AM
Jza's Avatar
Jza
Just a thought, you may want to check out any posts on those items on the product review board or do a search for those. I'm not the only one who "dislikes" those particular pieces from Accel.
Old Dec 3, 2002 | 10:03 PM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
What he said. Those accel cap and rotors, seemingly like the rest of their line of "performance" ignition products, are crap. When i first got my GTA, I did a tuneup and put an accel cap and rotor on there. Not too far down the line my car started running like **** so i was checking things out and i pulled the cap off and everything under the cap was covered in fine plastic dust. It turns out that the top of the rotor was rubbing against the cap, obviously the manufacturing dimensions weren't correct (and it wasn't installation error). I put a borg-warner cap and rotor on there and haven't had a problem since. And BTW, you don't need to go through jegs for most of that stuff anyway. your local parts house should carry them.
Old Dec 5, 2002 | 01:33 AM
MdFormula350's Avatar
whats the price diff. in the b-w verses accel
Old Dec 5, 2002 | 08:56 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
This is one area i can kinda agree wabout accel. Unlike a lot of people, i have never had a problem with accel wires or the large cap HEI stuff, and i've used a lot of them. But the small cap and rotor set for the late cars has done what he's talking about to me.
The next cap / rotor i buy will be whatever i can find with brass terminals. Thats all that really matters. The cheap metal ones corrode and get nasty easily.
db057
Aug 22, 2015 08:17 PM
Sena'sIROC
Aug 2, 2007 12:37 PM
89IRO
Nov 14, 2002 04:50 PM
