Two Questions
Car: 87 GTA
Two Questions
First: Does anyone know where to get the clips for the fuel injectors that hold the electrical plug onto the injector, not the one that holds the injector in the fuel rail. My local Pontiac dealer can't seem to find a service number on it's computer.
Second: What is involved in installing a set of TRS 23 degree heads? I have a Superram, SLP runners, and ported plenum. I need emissions, so can I use the EGR with these?Oh yeah, This is for an 87 GTA with 5.7L TPI. Thanks for any and all help you guys can give me. :hail:
Second: What is involved in installing a set of TRS 23 degree heads? I have a Superram, SLP runners, and ported plenum. I need emissions, so can I use the EGR with these?Oh yeah, This is for an 87 GTA with 5.7L TPI. Thanks for any and all help you guys can give me. :hail: Supreme Member
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
You can only get the whole plug with pigtail from GM/Delco. You could always get the Help connector from Pep Boys or the like & remove the clips.
