Heads, Cam, Intake, and Computer Questions
Old Dec 3, 2002 | 10:53 PM
Justin91RS305's Avatar
Heads, Cam, Intake, Computer Questions
I have a 91 350 TPI.
Questions I have are what would be a good set of heads for my car, I've searched and searched and can't really find a good answer. With Heads, I might as well put in a cam also, so what would be a good one? Also, what is the difference if I port the heads myself over buying new heads and then maybe porting then. If I put heads and a cam in, will I need to have a custom burned PROM made? How much modification can I do before I need to have a custom burned PROM.
Would these heads be usable if I decide to put a supercharger on in a few years or so?
Current engine has 119K, but runs strong and has 175psi when I did the compression check.
If I try to port my intake, I read that somebody ported too much, said he ran a cylinder too lean, and burned up the engine, is that possible?
Thanks for the help. I've tried to search for these answer, and I have come up short.
Justin
__________________
Old Dec 6, 2002 | 06:34 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: Heads, Cam, Intake, and Computer Questions
It's hard to believe you can't find any info on
a good set of SBC 350 heads? What are your price
ranges?
Again, there has to be hundreds of grinds for the
SBC 350. What is your planned use?
Cost, time, performance, etc.. Have you ported
heads before? It is a major skill..
With a '91 TPI (speed density), you won't be able
to do much to the motor without getting a custom
prom..
Usable, or optimum? You don't even mention a head, so it's hard to say.. You can run a SC
on stock heads, but it wont' be the best combo..
Could of been me?? Wasn't over porting, it was
over reving on weak valve springs and the valve
seats got messed up..
Justin
__________________
Spend a few weeks reading the boards and
car magazines.. Stuff like this is repeated
ad-nausaum..
mike
Old Dec 6, 2002 | 06:36 PM
Bort62's Avatar
Mike pretty Much Said it all...
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
TreDeClaw
Aug 14, 2015 06:58 PM
